Thought this could help:
Bookmarking to read later. Thanks for the contribution
Very well written and was interesting to read
Very nice write up! We use a little 5v fan to discharge cells.
ooh yea, that too.
Interesting that cell 1 is the highest reading, my bms (d140) has cell 1 as the lowest reading and cell 12 at 50.4v. Its a new pack i have just built, should i switch the wires?
It depends on which direction you’re measuring. I suspect you’ve got voltmeter negative to pack negative, then using positive probe to measure each cell. If so, that’d work in the opposite direction.
Ahh i see, yes thats what i was doing, glad its all good!
Awesome write up @thisguyhere. Couldn’t come at a better time, as I am about to correct some drift on my 10s4p pack. Was planning on doing this with a bench power supply. Question tho; on you example, you say cell 3 is the drifting one, how come you’re applying the voltage to cell 7? Or am I seeing this wrong?
omg, this is why people need editors.
you’re absolutely right, that’s cell 7…
brb
edit- fixed it, thanks
Think this needs an edit as it seems a lot: “Variance in voltage readings in the “Cell Voltage” column should be no more than 0.75v.”
I was just asking for ideas to do this. U can also hook cells up to a toaster or hairdryer to discharge.
And u could throw all cells in parallel. I just did this to a bunch of cells and with a huge voltage spectrum 4.65-3.4. Barely got warm and took longer than I thought it would. They are 30q cells. How I got (3) to 4.65 was due to charging imbalanced cells after ONE charge. Some cells in parallel had become disconnected during discharge and due to that. Without a bms u have to be on it. With ur hand testing for heat at least.
what do you think it should be, less than 0.75v? 0.4v? i noticed balance charge definitely did NOT kick in at 0.1v, but it did at 0.05v.
i just took the median of the two from experience, because technically it should balance within 0.1v, but that wasn’t the case for me.
for sure, there’s many ways to create a load…i was just naming the most common, probably the easiest way.
of course, again, i’m trying to describe the simplest way to do this. it’s kind of impractical to parallel additional cells onto a P group when it’s already assembled in a pack.
o i didn’t understand that a variation of .7 volts being before attached to a bms. maybe not as clear as it could be and I thought it meant generally when building the battery and running with or without bms. whatever. but get that board out going to the po right now.
I’m doing this atm. Works like a hot damn!
Niice
A bench dc power supply definitely makes it easier.
Also, them tesla cells
They’re tremendous cells, but in the future, if I use them again, it will be for a larger build, aka 12s6+p. Built for ev’s tho so more safety involved in the construction for vibration apparently.
Perhaps you meant 0.075V?
You’re right!
Fixing…
I just found my 13s pack that was reading 3.85/cell on the charger terminals, was 4.13/cell for 12 groups, and 0.0v on 1 group. I’m blaming the 13s bms. At least it prevented charging, which let me know to take a look…
Some stuff that helped me.
I found when pushing the voltage up on a pack with a lab PSU, the greater the current, the greater the voltage difference as sensed by the PSU vs the battery terminals. I ended up leaving a good multimeter hooked up to the battery terminals.
This thing is cheap and really helpful – the flip side to the lab PSU. Careful there are lots of lookalikes and clones. You can digitally set the parameters you want. It has 4 wire sense on the load connectors. In theory you can set the voltage you want to drain to, and the rate (amps) at which to drain, then walk away. Looks like they added tx/rx ports, hmmm…
Rigging this test lead really took away a lot of tedium and danger.
This splitter (15s => 8s,7s) and meter (8s, not super accurate) also very helpful. I made it to balance charge, but it’s very convenient when troubleshooting.
Here’s another meter that can do 8s, and shows all cell voltages at once. Only 2 decimal places, and accuracy is meh. Not as nice as the other meter.
https://www.amazon.com/Venom-RC-Checker-Discharge-Function/dp/B073SNZH4K/
Both meters come in many look-alike styles. The CellMeter style can be bought with light bulbs for decently rapid discharge function.
