If you are only riding on flats then you can use that as an average but if you plan on climbing hills you want to figure about 800 watts unless you have a sub 20 mph drive train.
At 10s8p you can really use just about any cell but it is still a good idea to use a high discharge cell because it allows you to crank up your braking currents if you need it without cooking the cells.
@Randy On a single drive yes, but only when sustaining that level of output during climbing or into a heavy headwind at high speed. A dual drive can do it all day… within reason. Too large of a motor on really tall gearing would probably heat up a set of VESC’s too.
That’s one of the reasons I like my voltage meter setup. I knew the HE2 cells I’m using sagged, but now I can see it. They sag .4 of a volt on flat, and as much as 1.2 volts on hills on my 4wd board. But with a 10s4p, the sag is a non issue. The sag was extremely annoying when I used these cells in a 10s3p pack with dual drives (same hubs as backs of 4wd board).
This is my issue constantly. Other than riding aggressively, I ride on steep hills that require a lot of torque. I was able to climb a 27% grade hill today and still maintain some fair speed for what my board can do. But I still need higher top speeds, I sit a lot at full throttle and generally feel slow, even though I top off around 24 mph.
Factory charge and discharge testing, from what I understand, is done in such a way that no real data can be gained. If you have time to watch, professor Jeff Dahn gave a very good lecture on li-ion cycle life and cell testing.
Very interesting,… so your theory (“more tightly wound”) about why the HE4 would have a longer cycle life than the HG2
(42:30 min video) is about the (More Pourous Neg Electrode), leading to less Plating ?
I suppose I should have stated “electrolytes of higher density”. I can’t remember where I found it but I have seen some test results where 2900mah density was the sweet spot at 1C. May have been a tesla related paper.
Aside from differences in cells one major contributer of cell life degradation is charging to 4.2v per cell every time you charge your pack. It is best to only charge to 4.15 the majority of time and charge to 4.2 periodically to balance the pack when needed or on some sort of maintenance cycle. Having a very large pack makes the loss of range a non issue since your the capacity is so high.
Their are many different aspects of li-ion cell management that play into overall cycle life.
Anyone know’s another source for the 30Q or HG2? both nkon and fasttech are not shipping to Brazil in the moment
I found some on eBay, but at a lot higher price and there’s a risk of receiving fakes
And what about the NCR GA? i know it’s not the best, but amazing capacity and a great improvement over my current NCR B, 40 mOhms versus 110 mOhms IR, and the most important factor is that i can order them from tumich on endless sphere for a acceptable price and shipping
I have gotten info from “endlessphere forum” that “Shenzhen E-fire Technology Development Co.,LTD” on Alibaba is a reliable source and have contacted them myself for Authentic Samsung 30Q cells.
$3.40/cell for 105 cells plus around 100.00 shipping + import fees .
