I realized that my supplier sent me caliber 44 instead of 50. The board will be more stable, but will be less maneuverable. I’ll test in the state and I’ll see if I change thereafter (the motor is quite ready the deck).
The concave is quite hard on the spud to the battery it will not facilitate the task of making a slim case. I may be having to sand the deck for a flat area below (ca learn from me too fast without thinking on achieving the project in its entirety)
I received my biddings freeboard. I think making a mix of spud whitepony and “bad idea” of adam0311 (which has lots of good ideas) about design.
A dedication to my fellow French OKP is a real source of insipiration and advice for the construction of this project.
Grip prototype:
drilling the biddings (thanks adam0311 for the “bad” idea
Remove the connector of the battery gauge and soldering directly to the PCB
then Sugru party time! (pain inthe @ss)
Working on the grip tape
I’ve recently a new little joiner in our family, less time for building eskate.
I had a problem with my DIY battery (OKP had to repair it, now i have to catch him to get it back).
I’ve decided few changes: i’ll put kegel instead FW (will use them form my next build), i’ve to change the driver.
I’ll put an 6574 instead the actual one (again i’ll use it for my next build, dual).
