I am currently waiting on a set of carvon speeddrive r truck/motors and considering different deck options.
What I am worried about is the clearance between the ground and my Enclosure. The Enclosure I am gonna use Is 38mm, but what are your thoughts on the clearance with a landyachtz switch 40 deck?
I am using 100mm wheels. Maybe I’ll need a set of risers?
Does anyone know the exact clearance of the deck?
I’ve got a switch 40 that I was going to use to make a mould for enclosures.
As it’s currently set up it’s very close to the ground. So I was thinking 25mm internal depth enclosure and top mounted and see how it looked. How much battery are you thinking of and what type of bms are looking at?
The deck is still sitting in the garage being used as a push deck. I got it as there was interest as a group buy and seemed to be demand for an enclosure… I’m so busy with other life stuff I’ve not got around to making a start!
