Ive been thinking about cncing some angled risers, but the max thickness is 1 inch and I dont know how to weld. So i designed a two piece riser that is secured by the hex screws to the board and truck as well as two more screws in the middle that provide additional support.
I’d suggest to 3D print the parts first to test fit and ensure your bolts can actually be inserted without hitting other things. Much cheaper is you know somebody or have one.
Do you know where I can get a set of these? I’m at the end of a build but stuck in a corner. I have channel trucks and a flat deck, so no turning without these. I’m desperate for a set of these if you know where I might find them.
