Just thought I’d share my latest build. I wanted to build something that was a little from the norm. The build consists of 36" Jet Potato board, 8072 - 220kv motor, Ebay modified pulleys 40:24 ratio, Psychotiller trucks and enclosure, group buy 10s3p battery, Abec 11 107mm, Drok voltage display, TB 12s esc, custom motor mount, and HK-GT2B Master Cho mod. The only thing missing is to still apply grip tape and make a tail guard. Board weighs 22.3lbs.
Haven’t rode the board yet. Somewhat scared of what this board can do.
that’s AWESOME! What pulleys did you use and modify? I have a set of E-Flywheels and only gear i know is the 3d printed gears. Would love 15mm gear option in aluminum.
I have to admit having access to a drill press is essential for modifying the pulley. The pulleys I used you can find on ebay. Just type in htd 5m. There’s really only one that I found on ebay that you can really use and that’s the 40t one. With the pulley you’ll have to enlarge the center bore (for bearing removal) and drill / tap for mounting. And obviously a spacer will be needed to take up the off set of these wheels to mount this pulley. I made mine from aluminum stock.
