I’m still looking for a deck to use for my build! I’ve seen there needs to be adequate clearance, and the goal is to shoot for 38" length or lower - what commercial decks do you guys prefer? I’m looking at building mine for getting around the city/campus, so definitely a cruiser - here’s what I’ve gathered so far! Trying to get a deck around $100.
Enertion’s mono drive motor kit
Turnigy 6364 245 kV motor
2x 3S 5000 mAh 30C Batteries
Enertion VESC
iMax B6 Charger
Anti-spark Plugs
Parallel Charging Board
(close to 180 lb. rider)
@michaeld33 I saw some of their products - its nice to see there’s a good budget range, trying to see if I can find any commercial longboards specifically though, cheaper the better for sure!
The beauty of DIY is your ability to electrify any board you like. Some are more challenging - like flexy decks (split batteries and electronics to front and back - middle free to flex), and drop decks (might not be able to use Enertion mount if doesn’t adjust enough to clear - DIYes and ADS both fully adjustable).
I’d also check out the deck inspiration thread for ones that look good to you and gives you a buildout to start with.
some reading, but it’ll give you a good place to start.
And asking what’s the best deck is like asking if you prefer blondes or redheads. And we all know redheads are F%@#ing crazy! hehehe.
