I got a common port Daly BMS and am not sure if that was a bad move… If i solder in second connector for charging as diagrammed below, will it be safe to charge whilst the VESC is connected to the battery? VESC 6.6 so I guess it’s sort of always on, right?
I want to take advantage of the push to start and not have a power button (and the VESC will be hidden in the enclosure), so kinda hoping that once everything is in there, the only interactions outside of the enclosure are with the motor wires and the charging port.
