Hello E Skaters! Im planing to join your community by building my own e skate
Based on my research so far, i decided that a single hub e skate would be sufficient for me, because i want to keep the price relatively low and only want to drive up to 25 km/h, also I only want the board to assist me and i will still keep pushing as long as im not to exhausted.
I want to use the Molicell INR18650 p26A Liion Batteries, they can provide up to 30a but are better suited for something around 20. (Test of Molicel INR18650-P26A 2600mAh (Gray)) here a Link of them being tested I read that the flipsky vescs are pretty decent regarding quality and bought an flipsky fsesc 6.7
Im a bit unsure about the motor though
I have those axles lying around,
they are pretty low profile and i thougt of something like the 70mm maytech hub motor, but the shipping costs from maytech are really high. I found quite similar ones on aliexpress (https://m.de.aliexpress.com/item/32947372538.html?spm=a2g0n.order_detail.0.0.1f056368EmdMeR&gatewayAdapt=glo2deu) what do you think ist there a difference? Did you have any experinces with those hub motors
I would also love to use some better quality hubs but the problem with something like meepo hubs ist that they need an extra axle and a motor on each side, or is there an adapter for ataching only one motor and a wheel on this axle? (rear TRUCK axle for shuffle s / shuffle s er / mini 2s / mini 2s er – Meepo Board) Sadly i cant find much other options for a single hub setup
It would be nice if I could get some opinions and ideas from you, because I really cant decide whats the best at the moment.
Thank you
