If I put 2x 5200mah 6s 10c lipos in parallel do I get theoretically 104A since it would be 10400mah 6s 10c lipo? Or since it’s in parallel do you only count one battery at a time? Sorry for most this is a very simple thing but I am bwry confused on parallel. Thanks
Yess, Thats right! But keep in mind that this is theoretically, and the C ratings on batteries are usually a little over-speced
Okay thank you I just needed to double chwxk before I order my batterys
Are these multistar packs you are considering?
Yes why???
Many people have found out that They dont really live up to the C ratings they are presented with. Is it lots of hills where you live? Are you going single or dual?
Dual, quite hilly. I do not need 104A it’s alot over kill. Will I atleast get 60A?
Hard to tell, as I’ve never owned a multistar myself… But you might consider some higer C batteries, even If the batteries can provide enought amps, they will have lots of voltage sag.
I’m on a budget and they’re 17€ off each so should I buy em?
As they were so cheap now I would say yes, but remember that you will Get some voltage sag. If you wanna lower this voltage sag, you can buy a third battery too. That way you will also Get some more range, but its up to you
Well then I’d go up in dell’s wouldn’t I?
Or do u mean 3x in parallel
3 i parallel
Might do that in the future
I wouldn’t suggest adding the third one at a later date. It’s usually not a good idea to mix new and old batteries
