Hello guys can someone help me out with a question for connecting a bms to this batterie pack https://www.trade-shop-online.de/li-ion_18650_akkupack_10s5p_14500mah_panasonic_ncr18650pf-p-133043.html am I able to just solder the wires from the bms to the pack without a spotwleder and if I can where? Thank you so mutch!
Yes, you can solder wires to nickel strip. Do it between the cells, one wire to either end, and then one per cell group in between. If you need more than that, go looking through the noob thread and other threads here on the site about wiring a BMS. There are dozens, many with pictures.
