This is not the first time but this time something went wrong
I plugged in my charger heard some small pops it was hot around the balance plugs but nothing is burned
All the wires as i can see are connected properly but the balance wires are connected bearly the cable is shot waiting for a longer one could that be a problem?
Measure the voltages with one probe on the negative power terminal (not balance connector) and go through each hole on the balance connector. The voltages should increase in the same intervals from one side and decrease from the other. Do the same with the probe on the positive power terminal. This way if it all looks OK you can rule out the battery and proceed with the BMS, send pictures of it.
And just to make sure you dont damage anything dont use the BMS until you fin out what it is.
Yes that could be a problem but I had this problem with my BMS and mine just did not len current through it did not smoke.
So i cut the negative wire from bms to vesc and now to check if vesc works i took a thin wire and like bridged the cables like battery negative -thin cable - vesc negative
And it sparked it never did that before battery is li ion so it shouldnt spark as I know
Please someone help fast its not easy to be in this position!!
Disconnect it and check with multimeter all the power lines against ground. Most probably one of them will be shorted.
And make sure the VESC was getting power since the bms is questionable at this point. Ideally try with different power source but only if the main power leads on the vesc are not shorted so that you don’t short your battery or powersupply
I was connecting it directly to the battery this time
Without the bms
While i was cutting the battery wire thst went to the bms i heard a pop and if i remember well the vesc just turned off
Also I dont have any other power supply than my battery thats compatible with vesc only got 2 car battery chargers so thats 24v wich could work if its possible to connect those two together to get 24v
I will look up how to check it aggaints ground and try that on monday
Don’t try it with the chargers, battery directly is enough since the point was to make sure the bms wasn’t preventing the vesc from turning on. You just measure resistance between ground and positive terminal input on the vesc, 5V on for example the hall sensor connector, and 3.3v on for example the programing header.
Hi,
What happened to @Acido happened to me but instead of having a small pop and being hot it when into flames. This is the configuration that I had when it went into flames:
