Connection identification
Hi all
Could somebody please identify what size JST connection is pictured here. I ordered a micro and that was too small. I am assuming it’s the next size up but don’t know what that’s called. inCollage_20190827_170112018
Thank you.
Give us a scale - a ruler next to it, preferably in millimeters.
Sure thing. 8mm x 5mm.IMG_20190827_174141 @MysticalDork
pretty sure they are all jst-ph 2.0
if this is the same size as the connectors then i am certain
For future reference, the main identifying feature of those connectors is the pin pitch - the spacing between them. The external dimensions are much less critical. Common sizes are 2.5mm, 2.0mm, 1.5mm, 1.25mm, and 1.0mm.
wire-to-board-connectors-table
Awesome, I appreciate the responses! I have been able to order the correct one now. Cheers.
