Hey there everyone,
I know this might not be the right place to post, then again it seems the better VESC (OK, ESCs based on Vedders ESC) makers hang out here, so I might catch them all instead of looking up contact info.
Might also be interesting to see what the community thinks.
So: Having looked at the schematics for the VESC, I see it’s fairly easy to add an adjustable 4.7-12.v 1A output for head lights and break lights.
This would mean that the VESC would make the skate/longboard EUstreet legal (Something I think we European riders should honestly care about if we want regulations to allow us to be on the roads like in other countries. Right now there is no regulation on electric skateboards, one can only imagine it falls under the same ones as for electric bicycles / kick scooters)
Sure, one could buy RC parts or do it with an Arduino but the question is why?
You’d need:
Batteries (1-2s) OR a voltage regulator since you dont want to feed the lights your 3-12s.
And a battery enclosure.
RC Switch taking up 1 CH on your tx/rx (for head lights, whereas I’m pretty sure the VESC keeps track of time since it monitors watt usage etc, it could easily switch on the lights based on date and time OR one could program the VESC so that if the breaks are applied when the board is standing still for X seconds, it recognizes that as a light switching input and one could rotate through different modes) UNLESS you want to have the headlights turned on all the time / add a mechanical switch.
UBEC/SBEC to convert the voltage, unless you manage to find lights that take the specific voltage the battery delivers, limiting your options (For example bicycle lights rarely run on 3.7v iterations)
Some controller that detects when breaks are applied.
Wires.
Space.
Time.
So why not add this? I can’t imagine it would be more than 4-5 USD of parts and I am fairly certain it is not much work to modify the firmware (Heck, I could give it a shot)
Another feature could be adding a secondary output for LED lights.
Also: Why doesn’t the VESC feature ABS technology?
What do you EU users thinks?
