I currently have a space cell, torqueboard’s esc, and single enertion r-spec setup like @lox897 said.
Unfortunately, I haven’t been able to solve the 80% problem, even though I live in a completely flat area…
settings I am using:
My acceleration is set to the lowest setting (which surprisingly, is actually pretty quick).
max forward: 80%
no reverse, 80% braking (a lot of braking when you slam on it, but I like being able to stop on a dime just incase…)
motor timing is also at the lowest setting, which makes the overall speed slower, but cuts down on amp draw.
basically, the problem is the space cell’s max of 60 amps; it isn’t a bad thing, just torqueboard’s esc is a beast, and was designed to pull more than the space cell can handle. tons of people use it with lipo’s of a higher discharge rate without a problem.
Solution to the 80%!!!
Buy a VESC instead! not bashing torqueboard’s esc, it really is awesome and easy to program; just for the space cell, a VESC is way better. Also keep in mind that all my settings are set up for my weight (140ish pounds, 65kg) on 14/36 gearing. I have also tried 13/36, and 16/36, but the middle ground worked best for me.
When my dad took my board for a spin, he blew the space cell’s fuse (standard automotive fuse; cheap, and easy to replace) within 5 seconds of riding it… he weighs about 200ish pounds, 95kg).
good luck man!
