Hey guys, I have a question hopefully one of you can help me with. I accidentally changed a few settings in VESC tool and all of a sudden my board seems to limit at 30A motor current. It stays hanging around 29.something. If I go full stick I see in the bluetooth app the motor current stays at 30A max.
When I go into VESC tool and look at the settings for max motor current en max battery current they are all set to a higher value. What is causing the motor current to max out at 30A (also the battery voltage sag is very minimal, so that also should be the problem.
Single drive, Maytech VESC, SK3 motor.
I used to defo pump way more amp through it. It would launch pretty insane. Now something is limiting the current at 30A.
I was looking to the remote controller settings and was wondering about it being set to ‘current no reverse with brake’. How does the controller influence the actual output speed of the board in that (standard) mode. Is the PWM signal value translated to percentage of the max set current?
These were set but seem to be off now indeed. I did replace the receiver because my earlier Benchwheel receiver died. Damn! Such a simple fix…
Wasn’t the place I was looking.
I did a quick ride and all is good again. Thanks bro!!!
This does make me think about failsafe behaviour. What if the current sensor fails, could the board go into full throttle? (A bit of a side question)
