I recently just started building my second electric longboard. I wanted to build a 18650 battery but didn’t want to solder every cell, and didn’t want to spend money on a welder. I saw that vruzend.com has their diy battery pack plastic pieces, but I thought those were too bulky and for a pack with more then 30 cells would be a little more then I wanted to spend. So I thought why not 3d print holders and make my own case that I could just slide the batteries into? For this build I ended up deciding that I just want to buy a sled pack from someone for simplicity.
I know a lot of people don’t want to weld or solder their cells, and I thought some people might be interested in purchasing a pre-built battery sled. So I am currently considering 3d printing small packs and for people who are interested, I would assemble the packs into small or large battery packs and solder wires to the slots that have nickel strip (or some other form of connections) as connectors. Since I would be designing and 3d printing the holders, I could make any sized sled for custom builds. All you would have to do is slide the battery in and connect a bms.
Now I am still designing how the sled will function and how it would hold the batterys, but I wanted to make this post and ask if there are enough people out there with an interest. Each pack would be roughly $30-$40 depending on the size of the pack you would like. So let me know if anyone would have an interest in purchasing one or if you have any other ideas.
These had problems with the forces from the enclosure pulling some intermittently out of parallel but winfly has a design as well, as well as other people. I think trying to sell prints it’s sounding like nese battery and it either using compression foam or something more experimental. “Works” is just a step away from fire when it doesn’t work. But we hope u make it
So there is a need for these, it’s just that no one has really been able to produce a cheap design that holds together without the risk of blowing up, and that can handle the amps without melting?
I dont know if you are interested, but i can make welded packs about as cheap as any method you will find here. I charge at most, $10 an hour for labor. Usually its lower
