Hi,
I have a problem with the configuration of davega config.h the km / h does not correspond to that of my gps… how to do ?
#define DAVEGA_CONFIG_H
#define VESC_COUNT 1 // number of controllers: 1 = single, 2 = dual
#define MOTOR_POLE_PAIRS 14
#define WHEEL_CIRCUMFERENCE_MM 305
#define MOTOR_PULLEY_TEETH 14
#define WHEEL_PULLEY_TEETH 27
// Affects the speed indicator. If MAX_SPEED_KPH is exceeded, no major disaster will happen. // The speed indicator will merely indicate the current speed as the max speed (all blue rectangles // filled). It will still show the correct number though.
#define MAX_SPEED_KPH 60
Spec board :
Flysky motor 6384 190kv 4000w 14poles (13s)
Flysky VESC 50A 4,12 (13s)
10s4p 13600mah (10s)
Bushing soft Orangatang
Truck style Paris 30cm
Wheel 97mm
Sprocket motor 14 & wheel 27
Entrainement chain
Box 3D print
LED
Remote Flysky basic
Davega Flysky
Thank you !
