Debating max6 vs vesc and 8s/12s
Interesting. I’m just thinking about running max6 now. And maybe upgrading later. Maybe once a couple cheaper vesc6 options are out. And btw. I’d like to purchase your direct drive setup that you produce and sell. Should I pm you or would email be better??
@Minim
Max6 is the oldschool stuff … Rough and not good adjustable Vesc is the fancy stuff… like a new uptodate car… with ABS, EPS, Apps, Sensors
With MAX6 you can build strong and light Setups wich are great for freestyle stuff… you will never have to worrie about heat, water or dirt… even mounting is so simple… countersunk the Truck screws and velcro them to the tip… done
@lunasicc Best is you send me an email : [email protected]
Cheers
sounds good, thank you!
