I’m on my second longboard and I’m starting the electric conversion, but the nose is starting to delaminate next to the truck…how do you make sure a deck is quality? (I’ve bought 2 completes for $70 from Target and $50 from Amazon and this happened to both). What is a reasonable price for a nice drop deck that will handle rain and abuse?
Also any recommendations for something under $100, something switchblade shaped? Or is it reasonable to make one from scratch?
Get a Landyachtz Evo or Switch 40. They are comfortable and tight. They are both reasonably priced at around 130. That’s a minimum of what you can expect to pay for any decent deck.
How well would the shreadskate hold up to being almost completely cored out? The original plan for the Minority deck was to carve out a 25’x8’ area (17’ for batteries 12s4s 18650 and 8’ for ESC/buck converter/Arduino/BMS/plugs) and maybe some steel rebar to stabilize it
Depending on the size of the veneer and the number of plays you should be able to route out some I wouldn’t go super deep just so the board doesn’t become flexy. You could also strengthen it by doing a carbon fiber or fiberglass layers
Too many bolts actually weakens your deck. There is no such thing as an enclosure that will stiffen the deck, only a really strong enclosure that resists impact. If your relying on an enclosure to keep your deck rigid then you are gonna have a bad day.
A layer of CF on the bottom of the deck, after the deck is routed, will vastly increase the strength of the deck, but you need a good deck to begin with. 9 layers at least and preferable hard rock maple or similar strength material.
If 3/4 of the deck gets routed out until the majority of the deck is half the original thickness would CF still make a difference? The perimeter would be maybe 1.5" on each side after
Also a good idea. If you want something flexy get a Bustin, they are plentiful on the west coast. If you want rigid get an Arbor or Landy. If you want a deck specifically for esk8 get a Red Ember, buy be prepared to pay for the quality be patient. Also, hummindexk are pre-routed and have layers of CF and are very well priced.
That’s an impossible question to answer. It requires that someone has done it using that specific deck. My guess is no as most decks are less than an inch thick, if you take 3/4 out you no longer have a deck but a very thin box.
@irdesignes is right, get a hummie deck. Pair it with a @psychotiller arc v2 enclosure.
