Ok, I updated my Focboxes to 3.40FW, run the motor wizard and the input setup wizard.
The update was performed using the TCP bridge on the metr.at app.
Everything seemed to work fine.
I started experimenting with throttle curves (no belts attached), I am not sure what happened but at some point everything stopped responding.
Now my master focbox can’t connect to the VESC tool.
The slave connects fine with the USB or with the metr module (if I connect the module to the slave)
It does not matter whether I try to connect via the metr pro module or directly with a USB cable.
Before anyone asks me, I did not at any time disconnect the CAN cable.
I have my new SurfRodz with psychotiller mounts and six shooters coming tomorrow and the bloody thing does not work (AGAIN )
Guess you already restarted it many times.
Did you try to disconnect the can bus and get connection if it’s a single unit?
The usb cable work on the other focbox, so it’s not the reason…
Maybe also try to disconnect the bt module and try only to connect via usb.
Check then actual usb port on the focbox. Make sure there’s a solid connection. I had to remove a bit of material on my plug to get it to connect reliably
Yeah, I have thought about that.
Unfortunately I do not have one and it would take weeks from one to arrive from China.
Even then I hope flashing a new bootloader and firmware would solve the problem.
Anyway it seems I am screwed
This is the exact same fucking thing that happen to my Focbox two days ago. The Metr Pro fucked it. However the only thing I did was to “read” motor config. It gave an error, and what you know. Master went only blue lights.
Crap, I did the same thing to check if all my config was sent to the focboxes.
I got a message saying the app is not yet compatible with the firmware and next it did not work.
I never thought it could have caused the problem.
