any news. I really need this bms to finish my board
Yes and it even works on my board (this is just a sample release, I don’t know when everyone will receive this)!
Is the group buy still active?
Yes I believe
Yes it is. Last status was that people has signed up for 33 pieces. @Samau18 wants 50 pieces in total before ordering. So sign up and let’s make this happen
Yeah its been slow as its not a bms for everyone but I definitely want one. Just look at the support and upgrades from @jtag. you’re actually getting alot of worth out of them too over time as more features are tested and introduced
We are at 40 pcs guys.
Filled out my interest, but just a quick question, if I already have a 50.4V 4A charger for lipo batteries, that would work as a power supply for this, correct?
Another basic question, what is the pcb size in total?
Hi JTAG,
I am just extending my battery to 12s10p via 4 x 6s5p. Got two DieBieMS and want to run each on 2 serial 6s5p as 12s.
Could it be possible to give each DieBieMS Module a difference CAN ID like 10 & 11?
Got two Tramps VESC6 and dont know how to wire the CAN connections.
Do you got any advice?
Will the 12S10P always be a complete combined pack or will they be separated in 12S5P form time to time? If it always remain a 12S10P pack than you should put both 12S5P strings in parallel (also the balance leeds) and just use a single BMS.
Yes you can change the BMS CAN id to anything you like with the BMS Tool.
Hey @JTAG Would you be able to answer my above questions relating to the size and charger requirements of the BMS?
I think I signed up in the google form, but could you verify I did? I don’t want to double up on signing up, that would mess everything up.
Thanks!
I see your entry. thanks
140x60x15mm is the size. You would want 3V above your charging voltage. I am not sure if your 50.4V will work. I defer this question to Danny to confirm @JTAG.
Just curious as to what is the ideal charger to use with the bms for 10s and for 12s?
+1 This, I need to be prepared when BMS arrives.
+1 from my side
Good news guys, we are close enough that I feel comfortable starting. Will start the material purchasing now. Pcb design I had talk to Danny, we will make some changes to help production test the boards easier, aside from that I believe there will no changes from batch 2.
What sort of lead time would you say, approximately?
