I has been a while since my last batch. Will start a batch 4 gauge to see if people are still interested.
I have heard feedback from previous users for some misalignment of the IC placement. I still remember this and will make sure this batch to be improved.
Batch 4 interest
Quote for Batch 2 post
The deliverable are as followings:
1 x DiebieMS v0.9 (2oz PCB) assembled. (SD Card and RF module NOT mounted). Components I have stayed true to the original design including the expensive press fit terminals
5 red and 5 black x wire connectors (non-crimped) for battery and VESC 4x.
1x Male 16P connector
20 pcs non-crimped terminal for balance cables (some are spares)
1x Momentary switch
1x OLED 0.96 Display
4x single end male connector with cable (JST 1.25mm 5p, 10mm) (Display, switch, canbus)
1x single end male connector with cable (JST 2mm 4p, 10mm (VESC side can bus)
6x M5x14 spacer screws
1x 80A Fuse
Asking for 120USD/pc shipped to major cities around the world via Hong Kong Post with tracking Number. (~8-10 days) destination tax and duties not included. PM if interested, I will create PayPal invoices.
10USD/pcs goes to @JTAG as donation for the great design.
The new batch will start when I have received ~200 pcs interest. Would take around 4 wks to make. I am hoping by the time I get enough interest, shipping will resume and most of us will be able to do go out and do some e-skateboarding.
**** Remember to use CC/CV power supply with the BMS.
I have the same problem. I sent it to @JTAG too for repair of two of mine and I haven’t heard back from him since 24th of February.
My thinking was to send it locally to get it fixed faster.
Indeed should have sent it to you @Samau18
I was able to grab a hold of Danny @JTAG he told me he is working on a new version. But still some time away until completion. So a heads up if you can wait for the new one or stick to batch 4. If you want to wait, please do let me know so I can update the order excel file.
We have a bulk order!!!. So our numbers are looking good for batch 4. Danny told me there is a minor update to the design (only the diode on the input got replaced by a Pfet). I am waiting for that and I will work on a schedule for everyone.
now in Swedish
Jag bor i Mölndal. Men kan skicka.
Du kan ta kontakt med mig via messenger på facebook om du har det, eller smsa på 0702205538 så ska vi nog kunna lösa det.
Grejerna är helt nya i kartong. Gav ca 1400kr för det inkl frakt och tull.
Hör av dig så ska vi se vad vi kan lösa.
for the english speaking
Yes I can sell it to you, bla bla bla, I live there bla bla bla! Please contact med on, bla bla bla
