Hansg
#1
Hi team, I will to buy a new BMS for upgrade my system charger of my skateboard, I want to know which are the difference between these Bms:
Now I am new to this topic, thank you.
The best tech d140 is a charge only bms, and the hcx d223v1 is a charge and discharge bms with a eswitch built in.
A simple search would of done the trick.
this has some good discussion on discharge bypass vs charge / discharge bms:
