Hi guys. Just finishing up my build. Had a few test rides. I have:
Turning sk3-6354 motor 260kv
8s3p (hodgepodge of free 18650 batteries)
Entertion VESC fw 2.18
Sparkless 120a on/off switch
Torqueboards mini 2.4 Ghz remote controller
Enertion trucks and pulley
83mm wheels
The problem is I can’t get the torque everyone talks about, nor the top end. I can get up to about 15 mph. This seems very low. One calculator said I should get up to 33 mph (no load). With load, I should be north of 25 mph.
I’ll post my VESC settings when I can, but anything I should zoom in on? I’d like to enjoy it without investing more $$$ at this time.
I know the batteries could be questionable. If I replace them, what should I consider for about 10-12 mile range in an 8s set up?
You should all ready be around the 10 mile mark with the 8s3p. I’m sure the torque has to do with either the battery no supplying enough amps or some VESC settings are wrong.
I kinda semi disagree I’m running a 6s lipo and I got more than enough torque. Don’t get me wrong it’s not a smooth start but I can go up some long steep hills.
But I’m sure you know a bit more about eboads then me… just my opinion
chaka is saying that the 18650’s have way too low of a discharge rate because they’re most likely laptop batteries. Low discharge rate leads to underwhelming wattage.
I wanted to provide a complete picture with full disclosure. That’s why I mentioned the mix of li-ion batteries. However, the same lot supplied batteries to a different custom 6s2p using an RC ESC. It is torquey and faaaast.
When I can, I’ll post BLDC tools screens. I’m hoping some adjustments can help.
If I do replace the batteries, any suggestions on a lipo for the same 8s set up? I’ve invested in a 33.6 charger and understand my motor can’t go to 10s due to high kv?
The more the mAh the more the range, but also the more the price. They would work! I would have some VESC experts look at ur settings. Also if u go with the batteries don’t forget a balance charger.
