bit of a weird problem. I can ride for about 2km and then the controller starts to disconnect or the VESC makes problems. I can’t really determine where the problem is located. In the BLDC tool I get no failures.
My setup is a VESC-X (or FOCBOX now) and a Nano-X controller.
Anybody knows this problem and what it causes? Really annoying to go for 2km and then it disconnects continuously.
it disconnects. then auto-breaking goes on. turned that off that I at least roll out. It disconnects usually for a second or so and a couple of times in a row. After disconnecting the VESC from the batteries it goes fine for some time and then happens again.
Thanks for the help so war. Rebinding I already did. Over temperature I also thought as we have here mainly over 30 degrees Celsius. I opened the cover a bit more for airstream to cool it. But had also no real effect. Obviously can’t rule that out completely.
Is there anything setting wise to keep the VESC cooler? Reducing amps or something like that?
