I have one blank pressed. Should I use it to make this board?
Yes I want to see something
Michrasubhransu, we are not sure about that yet, but I imagine 90mm would work fine. Motor clearance will be a good problem.
The kick comes up.
People use 110mm wheels btw
Then they can use more riser or talk to me about a cut out shape.
Iām talking most people use it. Iām not sure how much of a riser you would need with this deck
Iād like to see one myself not just a computer render
I was debating using the blank we pressed for the raptor 2 set up, but this one will be used for this board. I need to know before then exactly what size the enclosure cuts are going to be.
What cutout do you have in mind, Iāll tell you if itās good or not
I donāt have any cut outs in mind for this deck in this group buy. Programming a new shape for a board however in the CNC takes about 2 minutes, so basically people can have what they want, but that would not be a question for this thread.
Max sense to have the biggest cutout possible (and sensible) and the same cutout. Because no one is going to make several different enclosures for the same board
Oh when you are referring to cut outs, are you referring to the battery enclosure? Yes, that is still in the plan haha, of course.
I was talking about cut outs so freaks can put their 110s on it.
I shouldnāt have said that it isnāt for this group buy, because Iām totally down to give people different shapes for each order. Likely it will just cost another $20 to get a custom shape.
One of the biggest questions in regards to the battery enclosure is going to be motor mounts. Since this deck has a micro drop even outside the inner wheel base holes, there is a good chance many front mounted motors could hit.
I have almost no point of reference to see exactly how much drop we can work with having different motors, and motor mount locations.
LMFAOā¦ not all of us want those bouncy ball wheels
Most of us are freaks tho
Do you want a top mount with a kick, or do you want a cut out board (could have a kick or not) You seem to like throwing curveballs. I do want this set up to work with as many DIY kits as possible, and I think we can get it there, but 110 mm wheels are 110 mm wheels, and they get lots more wheel bite, and demand way more riser if the deck isnāt cut out. But hereās where these things begin to F with eachother.
I need to know where motors are located. If there are people out there thinking about buying this board, what kind of trucks do you have, and motors and mounts? Maybe if we do a cut out version which wonāt use risers, those people could use rear mounted motorsā¦ ?
People use risers if they use big wheels thatās not a worry.
People use different trucks but almost all motors are 63mm in diameter and either 55mm long or 74mm wide
Great, the main thing I need to know where motor mounts are placing those motors. If someone has a 3d model I can import it into this model, and take a look at just what motors will work with what risers ect.
I have a few mounts but itās all simple really.
Some mounts are long,some short. Some are fixed (not a lot and if they are they are the shortest mount possible) and most have adjustable angle
A short mount has a center to center distances of like 65-70mm iirc
So basically 70mm from the center position of the truck axle to the shaft of the motor
