I’m looking to build a 10s battery pack out of nokia bp-4l cellphone batteries.
I’ve got about 400 of these batteries, all brand new, albeit a bit old. they are 1500mah each.
http://www.cpkb.org/wiki/Nokia_BP-4L_battery
How many would I have to stack in parallel to power four 500W hub motors?
Would 10s3p enough or should I go with 10s6p?
And what should I be looking at in regards to battery protection/balancing/overcharge/overdischarge?
But they might have internal circuitry that limits ur ability to build a pack. Maybe break one open or find the info. Whenever I see those they have 3 connection points which is weird
Thinking again…I doubt those cells could handle any high current through them in series. So u build it and forcing high current through them they aren’t intended for. Too thin even if they don’t have internal fuse. So I doubt they’re a good idea but maybe discharge one Nd open it up and let’s see
Yeah I’d be cautious running them over 1C and that means to run 2000W of power you would need 2kWh of batteries or pretty much all your 400 batteries connected in 10s40p (which is ridiculous, not even sure how you’d fit that many batteries on a boards.
If you do go through with this it would be really cool to see, but I’m not sure about how viable this is.
If you can find a better estimate of the c-rating on these cells than the 1C guess then even 2C would reduce it to 10s20p which is already more reasonable.
