would it be possible that i make out of these 2 balance leads of the 6s lipos that im using in parallel a single parallel balance lead like in the drawing ive uploaded? i want to make a permanenet enclosure for the 2 batteries and make life a bit easier with the board
Personally I prefer to charge my Lipos individually, outside of the enclosure on my board. That way you can inspect the batteries after each ride (for safety) and then charging, in my eyes, is going to be more consistent as the charger is focusing on one set of cells (1 battery). That said, you can buy parallel charging boards from eBay.
