Usually there is a flat rate box for around the same price as a flat rate envelope. Boggles my mind that they wouldn’t ship in a box.
I guess when I order I will change the shipping type or something via email.
i am exited for this battery build , i was planning on a 18650 pack but this might be better !
I will be posting updates throughout the build and during testing. Theoretically it will be 378 watt hr.
Look forward to your battery build !!!
Looks like it will be satisfying finishing it
It’s gonna be a fun project.
Hope you get brave and do a video
Nice, dude!!! Super clean work!
I’m upset that the 4th cell along in that picture has been glued in with an extra 2.6 degrees of rotation.
Got cells from Lion wholesale today. Funny but they’re a little different than the ones I got from eBay. Both have authenticity sticker and same print. Positive terminal is different and diameter is different. LW on left, eBay on right. LW fits spacers. One might be an older version? I might be crazy but I ordered more from LW to make sure my pack has perfectly matched cells. Gonna set the 12 from eBay aside. Prob post them on the eboard market.
eBay must have sold you fakes? Do you have a battery tester to test the mAh and voltage curve?
They came in authentic boxes and had same print and authenticity labels as the one from Lion Wholesale. What tester do you use for that?
Could you contact liion wholesale? Maybe they maye shed some light on this… at least they should be aware that such batteries exist, I think.
is the weight of the cells matching with the specs? I did read somewhere that fake cells would be lighter…
I seriously doubt that they are counterfeit. Probably just an earlier version. Anyway, I’m testing a couple of them to see what their true capacity is. I’ll post results shortly.
hot glued and spot welded.
spacers take up too much room in the box in my opinion.
what charge do you use to balance each battery?
not sure if blood or paint.
satan cant help you make good packs dude.
Nominal voltage 3.7v for Li-ion
