i´ve created a double motor mount for MBS Matrix Style and similar mountainboard-trucks.
With little adjustments on the axle channel it should also fit other trucks.
Including counterbearings and belt tensioner.
Maybe it can be used here.
The .step-files for milling and Fusion360 .f3d-files you can find on Thingiverse
Where did you get the wheel gears from? Did you CNC those yourself also? I have a MBS colt90 with a DIY dual mount but this thing looks so nice. I’m hoping to get a CNC in the next month or two. This will be my first time having a CNC so I’m sure there’s a learning curve. Either way that mount is amazing looking. Oh one last thing what CNC machine do you have?
Until now i cannot say much about the performance of the SK8 motors - the board is stil under construction and i am on vacation at the moment
But the quality seems to be very fine and the power performs great (a friend already has a mtb with two of this motors )
Man I love this mount. I wish I had a cnc I’d give it a try. On another note did you top mount your batteries or do you have an enclosure on the bottom? I’m thinking of moving my battery enclosure from the top. I currently use lipos but I’m thinking of moving over to 18650’s or 20700.
Also do you have any feedback about the motors yet? I thought I read somewhere that the motor does not come with the keyway for the motor shaft. Is that correct?
The board is ready. Today i did the first testride. Everything works very fine
Asphalt with 17% gradient - no problem - easy to drive relaxed.
Off-road - up to the limit of grip of the tires. Performance at any time in excess
Sooo much fun
Loving this. I work above a cnc shop and was about to spend $300+ getting a set shipped from the UK. What matrix truck’s specifically are you rocking my new friend?
Hi, i use the Matrix I Trucks. But with small modifications on the CAD-Files the mount should fit many other trucks.
I think Trampa-Trucks are quite similar in the mounting-area of the motor-mount. Maybe it fits, but i cannot test it.
Try a Chinese prototyping service (e.g. Gel Rapid or Nice Rapid). I got a few esk8 and also work related parts from both services. Price are made quite random, so are the shipping fees. Get a few quotes and select what suits you best.
