Hi, I’ve been planning to make an electric skateboard soon and I was wondering if this ESC and this Motor will work together.
I’ve read on the forum that I can use a dual motor ESC to power a single motor but while reading the amazon page, It said that this specific ESC doesn’t support belt drive system.
I was wondering how that works? Can I not just plug it into a motor which allows it to turn and then attatch a belt drive onto it? How would the ESC know that the system is a belt drive? Not sure how this works and would apreciate any help!!
I was also wondering if the current draw from the ESC is also compatible with the Motor I have listed so it would be great if anyone could help me out and let me know if they can be put together.
ESC - https://www.amazon.ca/dp/B08RB1QCW4?ref_=cm_sw_r_cp_ud_dp_NAHHQNGCYDYRG90MM1CM
Motor - https://www.amazon.ca/dp/B07QNL8TSM?ref_=cm_sw_r_cp_ud_dp_7EQ52J6BHCEZ4FJR6XNW
Thank you very much!
