Hey guys, this is my first post, so don’t be too harsh on me
I am in the process of building my first esk8, and I recently finished my drive train. I just want to know what you guys think of it and if it looks cool.
For my motor, I am using a single SK3 6374 192kv with 15mm HTD5 belt (gearing ratio 15:36). Both pulleys are aluminum. I am also using 100mm MBS All-Terrain wheels. I am also planning on running 10s as 12s is a little scary.
I machined the mount out of 3/8in (~10mm) aluminum sheet, and modified the paris trucks on a lathe. The mount is held in place by a screw, for which I drilled a small hole on the trucks to keep it from rotating, and it feels pretty solid with good clearance. I also didn’t make the motor position adjustable because I 3D printed some prototypes until I achieved good tension, so the tension on the belt is perfect. I have a 3D printed guard/fan on the back of the sk3, but I have no pictures of with it mounted.
Pics:
Vector
Update:
Added a belt cover and motor guard, adding idler pulley soon.
