Hi, im I’ve made a list of the parts that I plan to use for my DIY Onewheel and was wondering if someone could take a look and see if im missing anything + answer a few questions.
Parts list:
Motor: Fungineers SuperFlux 6 inch Hub Motor
Tyre: Hossier XR tyre
VESC: Spintend 75V/100A VESC w/ IMU
Footpad sensor: Fungineers Stompies
Batteries: 16s/2p or 16s/3p Samsung INR21700-30T cells
BMS: Don’t know which
Notes:
Will be buying a 3d printer and spot welder, but I have all the other tools that I will need so I will be making the footpads and 3d print myself. Will also be buying aluminium U-profile for the rails and drilling the holes myself. I have also come up with a design that should keep everything from overheating.
Questions:
What BMS should I get that can handle 16s/3p?
Can I have the cells divided in between the two compartments? (32 cells in the back, 16 cells in the front)
Will I need something like a OVP or resistor too limit the power coming back from the motor when using regenerative braking going downhill? I will be riding down a ~2km gentle hill almost every day half the year (ofc up too but I don’t think that will be a problem) If so what do I need?
Does anyone have all the measurements for the XR and GT rails? (preferably in cm)
