So I have 24 lg hg2 3000mah batteries arriving soon to build a 6s4p pack for my next project. I have some nickel 8mm wide strips to spot weld together. The only thing now is the spot welder I don’t want to spend any money on buying one as will just add to the cost. I do have a second hand car battery which is one option but I now also have a microwave which I could make into one as well. But which will be best battery or microwave. Ideally I would rather use the battery as its a little less Voltage and less dangerous and would have to strip the microwave and buy a couple of bits for it. So who has used either options and which was best.
just check that out:
I built one and modified it per the original ES thread (see page 3 for why added) w/ the additional schottky and TVS to prevent the Fets from being killed by the avalanche current. I’m not an EE, but as best i can describe it - your 1-20ms spot weld, has about 100+ms of energy that has nowhere to go after the weld - so it goes back (in a bad way) through the mosfets. Repeated use = cooked fets.
the schottky and tvs give a path to prevent this from hammering the fets. Folks have said it fixes the issue. it’s a couple extra wires, and the two components - not too hard to wire up in addition to the typical Arduino board.
I actually am building another version w/ copper plate (like flangefrog’s) and will probably sell my v1 when v2 is complete. No real difference other than flat vs wire underneath and want to place in a small job box to protect all exposed wires. I’ll throw v1 up for sale when 2nd one is complete. Slow/back-burner project.
HTH!
Wasn’t going to go out buy anything was going to try and use just the battery.
Dude what did you think happens with a microwave? You would have to buy stuff and put serious work into it. You are dealing with high-current electricity here. This is no joke!
Yea I understand that it’s high voltage would buy a couple of small switches to help control it and then some good insulation. Read through a few posts that show and tell me what need to do.
This.
Seriously - we are talking major injury and voltage/amps here. Do not fuck with a half baked solution or you can hurt yourself, or burn your place down.
please be careful. I’m not trying to sell you anything, just give you some links and info if you want to build one of the better DIY setup for spot welding. There also is a good writeup on one of the microwave setups too - it just looked a lot more involved than the arduino project, so i went the arduino route personally.
You might also check locally for one of the aliexpress plug-in spot welders that might be avaialable less than new.
Like I said was going to try the car battery first something along the lines of this
so you have a huge solenoid switch at home? That switch alone is probably as much as I paid for the Arduino spot welder.
No won’t be using one going to find a suitable switch to handle it all.
Good luck - there is a reason why he is using one you know. Personally I don’t think you will find a suitable one that is cheaper.
now I am scared of using mine unmodified - is it really that bad? Thought the guy knew what he was doing when he developed it so did not think something could go wrong using it the way it is.
@sl33py I have the arduino side of my welder done but I need some advice on mosfets. I am going to order IRF1324PBF, this tvs: http://au.mouser.com/Search/m_ProductDetail.aspx?Littelfuse%2FSLD33-018%2F&qs=sGAEpiMZZMuNo3spt1BaV59JaOcfH3NfeKEsaAH2zCqgb1IAtfQvvA%3D%3D
and this schottky diode: VS-100BGQ015
Are they the right ones? And where does the schottky diode go? Thanks for the help!
Sorry Maxid - not meant to be scary. Worst case scenario - you have avalanche current going back into the mosfets and they fail. When the fets fail (one or two or … ) it will arc on contact, so in-between each weld i just touch them to some scrap or eachother quickly before next weld. No spark - gtg!
When they fail - don’t replace just one - replace them all at the same time. I also upgraded from the IRF1405 to IRF1324PBF per others suggestions. Supposed to be superior (but twice the cost roughly).
(to be clear here folks i’m regurgitating what i learned from the ES threads - i’m not an EE)
It’s the two components (Schottky and TVS), and a few wires. Relatively simple and inexpensive - definitely supposed to help with longer life of the spot welder. The original design works fine, and likely will work well for quite some time. Some folks were doing unrecommended things like really long cables from the battery to the Arduino controller/board - and really long cables for the probes - those apparently make it more likely to fail.
My Mouser list for anyone to compare:
(Note all parts are x2 to build a second spot welder - so just order 1/2 of what i did if you want to build only one) Hopefully this will give you the specific models i found and was recommended to use. Can’t speak to “alternatives” very well, but you might pose those questions in the ES thread where the more knowledgeable experts can answer.I realize i don’t have a pic of the finished board ready to go. So on the ES thread i’ll “borrow” a pic of flangefrogs or one of the others to show the wiring and placement of the Schottky and TVS:
(Flangefrog’s lower board - note he uses copper vs aluminum, and mounts the FETs under the copper vs on top (to allow the legs to reach/contact the bottom copper wire/bar. I mounted mine on top of the aluminum bar, and built a small solder bridge to reinforce that connection (some have burnt the traces - this is intended to help prevent))I definitely recommend reading through the linked ES thread, and the original one regarding Riba’s original DIY spotwelder kit he offered. Last i check around 24 pages… but tons of good info if you have the patience to read through it all. Here.
Best of luck everyone - happy to help as i can if you have a question let me know!
Thanks sl33py. I see where the schettky diode is now. It is that thing at the bottom right? Just beneath the wire
Just tried my spot welder with a 700A car battery. The current is large enough so that solder melts when I hold the tips on a piece of it. However I can’t connect two nickel strips permanently. They stick to each other but can be pulled apart very easily. Any idea? Blown Mosfets? Is there a way to test if they are good or not?
if the mosfet fails - it should allow voltage all the time and the tips should spark when contact (without foot pedal actuation).
without power - there are a few steps to use multimeter to test. Easiest (i’m no expert) is to follow some folks who know what they are doing and the steps via a quick google search. Some testing looks to require a more advanced DMM with features my inexpensive DMM does not have.
If you find a mosfet has failed - i’ve heard that it’s best to replace ALL the mosfets at that time. Any you leave will be prone to fail and replacing all is the best solution (again from the ES thread).
If you have a really powerful battery (not sure if 700A qualifies) - i know folks recommend adjusting your pulse time down, or even downgrading to a smaller battery. What settings are you using, with what thickness? I did some test welds on a dead AA battery w/ some 8mm .15 nickel - rock solid and hard to remove even with pliers. I do notice a difference between fully charged vs a bit low.
From flangefrog he recommended the following pulse times (again varies depending on battery i’d assume):
[quote] I tried both 0.2mm nickel, and 0.15mm nickel and copper. About 8ms worked well for the 0.15 nickel and 12ms for the 0.2mm nickel. Less time would probably work with a newer battery.[/quote]
@maxid - Let us know your settings, and thickness of what metal (nickel or nickel plated steel?) - i’d guess adjusting the pulse time down first.
@lox897 - yep the square schottky diode is under the wire that has the TVS diode in the middle (above/alongside the board). The orientation is the pointed end goes towards the wire to the probe.
Hope that helps!
@thefer @Blacksheep This is the basic schematic of the one I made. Nothing fancy but it does the job. Theres also no way to accurately time the duration of weld so I practiced my pulsations with my index finger untill I was as calibrated as a torque wrench at nasa aka I spent like 30 mins trying to to melt the shit out of the strips. I also practiced on a few dead AA batteries I had laying around and that really helped. Lugs 4 Gage Cable Momentary Switch 14 AWG Copper Wire
Also, grounding wire goes from the transformer to the ground in the plug.
Is there a new version of the Arduino Spot Welder you can buy ready to use with the avalanche current problem fixed?
