Hi there, I am looking to create a better solution to hold my batteries and VESCs. I was wondering if anyone was willing to share their setups, experiences, advice, etc.?
Constraints:
Swappable battery (two 4s 5000mah lipos in series taped together)
Aestheticly pleasing
Waterproof
Currently, I only have the swappable battery part covered. Has anyone managed to create a setup like this? Has anyone tried cutting a hole in the deck and accessing the batteries through there, instead of opening the enclosure? That seems like the easiest way to hit all of the constraints… thoughts?
Cutting a hole in the deck large enough to take the battery in and out would weaken the deck too much.
What you would need is a quick access enclosure.
I did something like this on my first build using a clam shell enclosure where half was bolted to the deck and the other half was held on with velcro buckle straps.
the only problem I had with it was that it did not keep the road dust out.
If it rains, take a page out of my book and stay home
I once went like “fuck the rain” and rode on a barely wet road and ate dirt for at least 3 meters due to aquaplaning. The scar is still about as large as the quarter of a dollar note. I repeat, do not ride on wet roads!
Building it waterproof is nice to have though, and the swappable feature seems very useful.
I would like to avoid riding in the rain if possible, at most just riding to bus stops slowly aquaplaning does sound pretty terrifying on a board! I will certainly try and avoid it though.
Mine was not even dust proof let alone water proof.
There are however some clam shell boxes that have an O-ring that seals the mating surface and they are water proof.
http://www.serpac.com/rb-series.aspx
I like the idea of having a clear box, kinda like a window on a PC fan. It will also help with monitoring lipo batteries to make sure they aren’t puffing.
Neither of my enclosures are water proof. Splash proof yes but not fully water proof. I think the best option is a lunch box container with snap on sides and a rubber seal
