Hello!
If this is the right place for it, I was wondering whether anyone could look over my parts list and check if it’s OK? I also have a few questions. I have a background in embedded systems as well as UASs but I am not sure how many rules of thumb translate across.
- Trampa Vertigo Urban Carver - Superstar 7 inch wheels and Yellow DAMPAs
- Trampa Urban Motormount - 15 tooth pulley
- 72 x Samsung INR18650-35E in 12s6p configuration
- FOCBOX
- Eskating PRO motors 6374 190Kv
- Nano-X remote
Is there any real difference between the 3 Urban Carver boards and also between Hypa and Superstar wheels?
Is it true that the pneumatic wheels are significantly less efficient than urethane 90mm wheels? The worst material I will be going on is cracked road, no gravel or dirt, so are 125mm “Gummies” a compromise?
Do I have the right voltage/kV/gear ratio/wheel diameter? I would like to be able to go up fairly steep (25%?) hills and although speed is not a priority, range is.
The motor is rated for 70A, but the FOCBOX says only 60A continuous, and the 6p battery configuration should be 60A max there as well, my assumption being that it is unlikely to be drawing 70A for long. What kinds of current should I expect from the motor?
Will I every need to upgrade to a dual motor system? I weight 75KG, and I want to be able to take my school bag with me (on a bad day 5kg).
Thank you so much for any advice/help!
