is it possible that I have a defect motor? Whenever i try riding it it goed really slow. When it’s on the ground and nothing on it it stutters and doesn’t move. I have tried to redo my motor detection but it failed. I hope my motor is not defect because i live in europe and i bought it from DIYelectricskateboards.
defective motor? if it fails the bldc test most likely. have you tried opening it and seeing if the phase wires are insulated from the housing or each other.
you could also use an inductance meter for 15$ to check each phase or maybe if you get a really accurate resistance meter it will show up. the inductance meter and resistance meter on the vesc foc program test are really good and you might still be able to get some results from that.
It was working and then it stopped working? What voltage are you running? A failed detection could be the wrong battery cut off settings. Bad soldered motor wires. Did you check the faults?
i have 3 9s battery’s from zippy flightmax. Each 5000 mah and 11.1 volts. I have thos 3 batterys connected in series to my vesc. The vesc is a VESC BLDC Speed Controller that i got from DIYelectricskateboards.com. My motor is a Electric Skateboard Motor 6355 190KV also from DIYelectricskateboards.com. I also have a TorqueBoards 2.4ghz Nano Remote Controller.
That’s all i guess. I have a link here that leads to a video of my setup
Sounds to me like you are actually running three 3s batteries in parallel (not series) for a total of 11v. That would be really slow. Also you should make sure your motor connections are solid
Please show us a pic or video (if video - more light so we can see clearly).
Specifically of your battery connections - how they are connected so we can validate if it’s in parallel or series.
It would be good to also see pictures of your connectors - as close as possible and use flash if needed so it’s clear. Looking for good soldering if you made your own connectors or replaced battery connectors.
Plus the above suggestions on VESC BLDC settings.
What’s your gearing? Motor gear # teeth, and Wheel gear # teeth?
