Hi Patrick, I made this mount for my own builds and for the fun of it. Not sure I will be making more or other versions of it.
I will be on holiday for a week, if any of you are on the fence about ordering, last shipping possibility will be tomorrow, otherwise you will have to wait a week for it to get shipped.
Some small tips for mounting these after doing it many times now. Mounting these on the TB218 trucks is pretty straight forward, just remember to use loc-tite on final assembly.
Screw in all the screws loosely. Screw in the set screw at the bottom of the truck (curved side) so it just about locks everything in place , then tighten the clamp down. Go back and forth between tightening the set screw and the clamp. Done. Other set screws are optional based on truck variations.
Caliber trucks are a bit trickier since they have tapered surfaces. I usually use the wheel pulley to align everything up. Take away the inner speedring, mount the wheel, and then you have something to push against to align it. Fit all screws loosely. Screw in the clamp screw until you get some resistance. Screw the first set screw (1) down until the mount has a loose fit against the truck, not to much as it then will cause misalignment. Then tighten the second set screw (2), and then the clamp. Then go over all of them and tighten down hard.
These are highkey not even mounted correctly btw. After a couple of hard impacts youâll realize this. maybe the loctite is saving you for now. Correct me if i am wrong @Deckoz but you want the mount to be flush into the curve on the right side as that is where the force of impacts is received. If it is flush there is no space for movement. As you have it there is a ton of space for movement.
FYI the only set screw you âshouldnâtâ use is the one on the curved side. i use shouldnât loosely cause i use all and loctite all
Hi guys, thanks for the feedback. I get your point but have not had any issues with this. I have not crashed into any sidwalks or anything yet. You could shim it like with the old c-clamp TB mounts if you do not want to rely on the set screws.
@Mikaelj I have received the goods! The finished on the mounts feels so sleek and smooth. Iâm very happy with them. I look forward to trying them out.
Looking forward to see them on your builds! Also any feedback is appreciated.
There are currently 3 sets left + one set I have used for testing, only dry mounted it to check fitment, will sell it with a discount if anyone is interested in that one. Barely any marks on it.
Do you have a list of all the hardware and their sizes (screws, nuts, bolts)? Asking because I seem to have misplaced the hardware you sent me. Thanks!
Been riding these a while now on my âLandlubberâ and they hold up nicely on this setup. No belt skipping whatsoever with 15mm belts, Kegels are locking up on hard braking, I am in the welterweight class (read lightweight). I think I will go down to 12mm belts as it seems more ideal for coasting. The ball bearings used for the idlers were not the best and started making rattle noises after a while, so I will swap out those.
