Hereâs a questionâŚletâs say you have one setup, 12s, 100kv motor, 2:1 gearing
then you have another setup, 6s, 200kv, 2:1 gearing
same size motor. Which has more torque? They have the same amount of power but one setup draws more amps at a lower voltage, one draws lower amps at a higher voltage.
With the same motor, yes it would. But if you have a motor of double the kv with the original voltage you draw more amps per volt, so the power is the same. It looks like this, given the motors are the same physical size.
300kv = 16.8 v x 80 amps = 1344 watts
150kv = 33.6v x 40 amps = 1344
