I’m upgrading the motor on my Gen 2 Evolve Board. The hall sensor cables on the stock motor are unusual. Is it possible to use the same esc with the standard format outrunner?
I highly doubt they are using something other than the standard sensor protocol that all Brushless DC motors use.
black goes to black, red goes to red, and the center wires are your A, B and C sensor data lines. The order you put them in does not matter. Just black needs to go to black and red needs to go to red.
I you wana keep things simple, I would recommend using evolves sensor plug, since you have a male and female plug already. Leave yourself 2 inches for safety (in case you mess up soldering and need more wire), and solder one at a time. Cover each joint with heatshrink and your good to go
The one your using btw looks to have a temp sensor wire (which is why theres 6 and not 5). You don’t need to connect the temp sensor, you can heatsrink the end of the wire so it doesn’t short with any thing.
