Short about me, I am from Denmark and study Integrated Design engineering (a crossbreed of a industrial designer and mechanical engineer) and love to make stuff.
This is the Donald Duck build!
The specs
Diy deck
Diy 3d-printed enclosures
Diy 3d-printed wheel pulley for 76 mm wheels (already had those wheels)
2x5s 3300 mAh batteries
6355 190 kv Maytech motor
Maytech vesc
The process
I wanted to make the deck my self. So i bought some cheap plywood and made a press with the desired concave out of what ever wood layering around.
A lot of glue and a day later, I could cut it in shape and sand it nice and smooth- The template of the shape was made in Inventor, with inspiration from the the Sector 9 striker deck. Very happy with the result!
Time to get Donald involved… I cut the pages to size and used a clear coat made for ships. 1 layer under the pages and 3 above, with a little bit of sanding between.
After some clear griptape was appleid, I was ready for a late night of assembling! The enclousers and xt60 holders inside, I also designed in Inventor.
But why Donald Duck? Because it’s awesome and it’s matching a fixie bike i made a while back.
But it’s not finished yet - if a esk8 project ever finish?
For my first electrick board, the power it delivers is for now - but the charging situation could be better. So the enclousers will be redesigned reprinted in better quality and same color in the near future.
What do you think?
And yes, the wheels are pretty small, so they will also be replaced at some point. But I dig the red tho.
Really like those enclosures. Any chance you’d like to share the files?
BTW, keep an eye on your motor mount. It looks like it might be bending very slightly. Given that you are running a solo 6354 motor, it will put a lot of torque on the mount.
Thank you all!
@Riako I thought so… @Jmding the enclousures still got some flaws. But when im happy with them, I will be glad to share and yes, you are right about the mount. It’s hobbyking on Paris truck, which is not that great…
Super nice! Love the Donal Duck theme, favorite classic Disney character. I really need to learn how to press decks. If you have enough pics and would like to share your technic with a tutorial about it, everyone would be super happy to read
it or watch it if you prefer a video. At least I will be!
Hobby king mount eh? That surprises me a bit, that mount looked pretty thick. Do you know Joe thick it is? Could you take a closer picture? I’d like to see where it’s yielding
Wow, a little surprising it’s bending. Most mounts seem to be 6mm, 8mm should be easily twice as stiff… guess maybe they got too trigger happy with the weight saving cutouts.
