Hey there! I’m thinking of using 2x 4s 5000mah lipo batteries in series. Im planning to use this BMS, but not sure if it will work perfectly. I will bypass the discharge. (https://hobbyking.com/en_us/8s-li-ion-pcm-charge-4a-discharge-10a.html) Will a 3-pin charging port be compatible with this? Like a hoverboard charging port. Thanks in advance!
Ports can always be changed
