Hello everyone,
I am in a custom montain board with a single motor (expandable to 2 in the future) I usually travel on flat roads with little inclination but I want to get the maximum speed and torque, distance will be enough with 15 km. My weight is about 70 Kg, wheels are 8 " and I will use a focbox. I will surely buy everything in eskating but I have some doubts about the motor and the battery.
How fast you wanna ride? Maximum speed is different for everyone
For battery I wouldn’t go below 4p for MTB, the more p the better.
I’m confused, do you want to top mount the enclosure or below the deck? Because you compare flat with square battery pack.
I have a dual drive of this motors on my trampa street carve.
11s4p HG2 battery pack and with a gearing 15:60 on 8inch wheels my max spead is around 50kmh with a good nice torque.
After one of my VESC broke I tried a single set up, but don´t like it so much. Nice to cruse but for a offroad session I guess it will be a bit weak.
Keep in mind that Eskating.eu had some troubles in last time with a fire and now try to work out all backorders.
So if you order there it can take a while.
If it´s not a problem for you, I can just highly recommend them.
Had only good experiences.
About the remote…Look for mini remote on AliExpress.
If it´s no problem for you to have a pistol trigger. They around 30€ and as far as I can say they work without any issues.
Thank you very much. I want to get at least 35 km / h on flat terrain, and 30 km / h on a vertical slope of 5 degrees. In the area where I live no more inclination. I 10s3p prefer slim battery because it will be installed under the deck. I also like that the total weight does not exceed 8 kg, so the configuration of a single motor
