I’m swapping out the trucks, motors and wheels on my board. Stock Black Onsra Carve, 1st gen with a DV6 Pro.
Trying to install: Surfrodz RKP 200mm w/ 10mm axles Torqueboards 6355 190KV MBS Rockstar Pro II Alum Hub + MBS 72T wheel pulley + ?tires?
There’s 50mm of space available on the axle. More than enough for the 38.2mm inner core depth of the hub. Will I need anything special to get these hubs to fit properly on the trucks with the motors?
Is there a good 10mm axle spacer pack anywhere?
I’d really like to use a flat profile, wide tire on these hubs. Is there a list anywhere of what tires will fit on these hubs? Like some 6x2"'s or something…
