I was wondering about the output signal from an ESC.
Is the amplitude of the output of the ESC always the same and it’s only the frequency that ever changes regardless of the input voltage?
For example, if my ESC can work with 6S and 12S, if I power the ESC with 6S vs 12S, will the amplitude change? Or does the amplitude remain the same, but the 12S just allows my ESC to increase its output frequency to allow the motor to spin more quickly?
I ask because my motor’s suggested voltage is 24-36V. Does this translate to 6S to 9S?
What would happen to my motors if I fed 12S to it, provided my ESC can handle 12S? Will 12S damage the motors? Or it just means my motors will be less efficient?
You can run any voltage a standard esc can use with a brushless motor. They are not sensitive to voltage, it just results in higher rpm.
They are sensitive to load/amps and heat, so if the rpm is higher than recommended you need to use a higher gear reduction to reduce the load on the motor.
As long as you keep the motor from getting too hot, all will be fine.
Additionally on 12s you should use a motor with a KV lower than 270, or the rpm may be too high for the esc to handle and your gear ratio starts to get ridiculous with a huge wheel pulley and tiny motor pulley.
270kv at 12s? My 1st inclination is to ask in what universe but I assume you are using a crazy bgear reduction to keep from hitting the ERPM barrier or a non-VESC ESC.
Ok yeah 190kv or lower is better on 12s. Currently using 140kv
I did in the past use a 270kv motor on 12s with vesc4 97mm wheels, had to use the 4:1 ratio 12t - 48t gearing and have eprm software limited to 60k. It would only hit the 60k limit on the bench though. It it was not a good setup due to the small motor pulley wearing out super fast, and the large wheel pulley being close to the ground. It did have kick ass torque though and really strong brakes.
