The charger needs to be the same voltage as your battery
I think space cells are at 42v So a 42v 2A charger should do it
Is there any way I can check the voltage?
Same thing happened to me a coyple days ago, i blew a comoonant on my bmsā¦
Make a solution of 1:1 90%-100% isopropyl alcohol to 100% acetone and get a tooth brush and clean all ur electronic parts. While cleaning look for burn marks on all ur componentsā¦ if the board turns on but isnāt charging u only have the bms or charger to look at
Connect a multimeter to the charger
I already checked and itās the charger which is fried, at least it looks like it since there is no output. I was asking about the battery voltage, and I will use the multimeter. The BMS looks fine and not burntā¦
Oh, just use a multimeter on the terminals the check the battery
The battery works, but should be there any sign of ālifeā on the charging cables? The ones which are connected to the plug.
with the space cell, near the display if you press around it youll feel a small button click. Once you turn the board on and do this it should switch from percentage to voltage
press around the area pointed to by Hassle Free esk8 Battery System, the screen should switch modes
