Lately I’ve done my first buld, thanks to you all in this community for all the amazing information available on a simple search.
My problem was my VESC DRV8302 fried after 5 days of use… didn’t use it too hard on the day but it was a big frustration.
I already bought another DRV8302 for 10 dollars (with delivery, thanks to RS-Electronics http://au.rs-online.com) Now I’m on the lookout for someone to replace it for me for a fair price in Sydney (where I live). I made lots of phone calls and found someone willing to do it for $50, which is ok but thought I could find it cheaper.
Going back to why the DRV fried, Don’t believe it was my configuration as everything was set minding the low current and low heat. below is my config. if there’s something wrong, please let me know.
Baterry: x3 3S 5000mAh - https://hobbyking.com/en_us/turnigy-5000mah-3s-25c-lipo-pack.html Motor: Turnigy SK3 - 6364-213kv https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6364-213kv-brushless-outrunner-motor.html VESC: MayTech http://www.maytech.cn/en/product/e-skateboard/e-skateboard-esc/e-skateboard-vesc
the funniest think (and someone could also explain to me why) whenever I connect the VESC to the BLDC tool, everything works fine, all the readings, real time samples, receives the signal from the PPM RC remote, no fault code at all… It just doesn’t send signal to the motor (also tested with a multi-test). the only error message I get is when I try a motor detection:
but then, as I said, not faults:
