For those of you on here with dual diagonal setups and both VESCs at the back of your deck, what guage wires do you run between the VESC and your front motor?
I know 12AWG is fairly standard for running between a VESC and motor but just thought I’d check if it’s worth using thicker wire considering that the phase wires would be a fair bit longer than usual.
