Hello guys
I have a Flipsky dual 4.20 VESC here and decided to model a case for it to go on a Trampa. Its shaped to contour with the Trampa but at the same time its nice and low profile but crucially allows the heat sink to sit on the outside of the enclosure whilst the VESC is bolted to it and sits on the inside.
Underside
Heat sink sits in a slot on the underside and then protrudes through
There are holes for the wiring to protrude either end, with built in grips so you can heat shrink the wiring to the case for a water tight seal
There is also plenty of space to velcro a receiver and bluetooth module inside
Is there any interest in this? can produce these in ABS or Nylon. I also plan to produce another model for the focbox unity soon.
I have already printed two prototypes along the way whilst designing and the fitment is good, I will produce a full prototype in ABS in the next few days and show it on the Trampa.
